Dynamesh Polygroups crash
I’m using Zbrush 4R2
while in Dynamesh I’ve used " polygroup from mask", and “polygroup from polypaint
I can do this once, but performing it again will crash zbrush…I’ve tried it several times and its pretty consistent.
I’m aware of the slice tool and the fact that I could also exit dynamesh>>Polygroup>>and reenter Dynamesh…
however being able to cut up my mesh using polygroups while in Dynamesh would be an extremely useful workflow if possible…any thoughts, info, or advice would be appreciated
I’ve had crashing issues with polygrouping from masking or paint. It was pretty consistent. I started setting up poly groups from visible instead. This seems to work so far without any crashes.
Thanx MentalFrog, combined “HidePt” and “Group Visible” is a doable work-a-round.
