dynamesh hard crashes the computer
hey all,
i’ve got zbrush 4r6 on a pretty beefy computer but for some reason dynamesh hard crashes the computer, when i defrag the hard drives, somtimes and i stress sometimes dynamesh works perfectly. Anyone have any idea as to why this is happening?
[SUB]it shouldn’t crash your computer.
If it indeed does do that, then it could be for any number of reasons: memory dump, CPU failure, overheating cpu
you need to check your logs and other clues first.
lemon[/SUB]
I did a cpu temperature test, and the cpu temperature go up from 60 to 100 and then the computer crashes, so i think it is the cpu for some reason. Seems really odd to me but anyway i think that’s what causing the problem
@johnfletcher Are you on Windows or Mac?
windows 8.1 pro
I’m sorry for posting here but did you manage to resolve your problem, I need to know because I have the same problem
I suppose that your computer have a lot of useless files which might crash your computer. I had the similar problem and using a special software helped me, so I think you should try to do the same thing as I did. There is a lot of this kind of software on the Internet and it’s hard to find something suitable. Check this article, this might save your time there you can find the best computer maintenance software for yourself. There are described the most popular cleaners so you will be able to find something great.
