dymamesh: more polygons... and reflections in matcap
Hi guys…I have 2 questions:
how can I disable the reflection in a matcap material ?
and second question is: in dynamesh I have 1024 as resolution…but i need more…how can i manage this ???
thanks :slight_smile:
For the second, that’s now how DynaMesh is meant to be used. DynaMesh is explicitly described as a base mesh generator. It is not what you’re going to sculpt and paint on. You use it to block out your form and get to the starting point, after which you turn DynaMesh off and divide/sculpt like normal.
For the first question, which material is it? I’m not seeing any MatCaps off hand that have reflection. More than likely, it’s a mixed MatCap with more than just the S1 shader. In that case, reflectivity is going to be found under the S2 (or higher) channel.
thank U for the answer :slight_smile: !!!
