Duplication
I noticed in the making time for art motorcycle video a little while back Pixolator creates a links for the motorbike chain and then duplicates it out several times to make the full chain.
Does anyone know how this is done, Is there a shortcut key used to duplicate mesh?
Thanks,
Chris
move action line (W). hold ctrl and grab the center of the circle.
There are other new things for masking, etc that are also covered in the documentation for what’s new with z4r2
To add to what beta_channel has mentioned, once you grab it, you can let go of Ctrl and press Shift to constrain the duplicate move to a straight line.
edit: I should also mention that if you constrain to a straight line, that it will move along the angle of the Action Line.
That is absolutely fantastic! So quick and simple - Thank you both so much!
