I was at a recent ZB User Group and Paul from Pixologic showed us a way to keep the draw size uniform even if you move, rotate or scale your object, but for the life of me I can not find that note - does anyone know where I can find the control that turns this on and off?
Example: I am creating a seam using the stitch1 brush and a repeatable alpha - the seam is not all visible in one seam and twists and turns around the leather in this chair - when I move or rotate the model there are subtle changes in the size of the model so I need a way to standarize the brush draw size for the entire seam.
Also, if there was a way to further stabilize my direction of travel along an edge it would be freaking awesome - Lazy mouse is great, but is not really getting my stroke as steady as I would like - still experimenting, but it would be great to be able to lock a stroke along an edge loop:).
My thinking is that the command would be along the lines of “preserve draw size” or something along those lines. I assumed it would be under one of these; Brush, Draw, Preferences, Stroke or some type of Plugin, but so far no luck. Any ideas?
