Draw Size/Focal Shift hotkey plugin is unresponsive
I’ve installed the Draw Size/Focal Shift hotkey plugin for Zbrush 4, but it doesn’t seem to do anything at all. Any idea’s on what’s wrong?
FYI - yes, I placed the AdjustDFZsize_4.zsc file in the C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs folder.
You will probably need to assign hotkeys (using Ctrl+Alt+click) to the buttons as they won’t work out of the box with ZBrush 4. The Adjust Plugin menu is in the ZPlugin palette.
Thanks Marcus. That did the trick.
A note though. As you have yourself noted, the cursor flashes while changing the brush size. I noticed as well that the brush graphic continues following the cursor position while you move your mouse side to side in order to change the brush size. This may be the cause of that unwanted flashing - two different events competing to change the cursor graphic. Just a thought.
Thanks again.
P.S. A piece of functionality from Zbrush’s default method using the s hotkey that I miss in your plugin is the presence and editability of the numeric value of the brush size next to the cursor.
Thanks for your suggestions. :slight_smile:
