Draw size adjust ?
Hi
How can i set the shortkey of draw size [ ] with every click to not scale draw size in 10 units but less ?
thanks
You’ve two options:
  1. The Adjust Draw Size plugin included with 3.5 R3 allows you to adjust the Draw Size (and other values) by moving your cursor.
  2. There’s an alternative plugin here which allows you to set the increment through a slider:
    http://www.zbrushcentral.com/showpost.php?p=371707&postcount=8
Thanks marcus_civis
but Adjust plugin in zbrush3.5r3 doesn’t work … wen i click on the adjust draw size and move my cursor , nothing happen , any suggestion?
You need to assign a hotkey. See here:
http://www.pixologic.com/docs/index.php/Adjust_Draw_Size/Focal_Shift/Z_Intensity
Thanks Marcus
i try Adjust plugin
but i really like the plugin Brush-Up-Down it’s better for me :slight_smile:
thanks
That’s fine, whatever suits you best. :slight_smile:
