I’m fairly new to zbrush and this is my first post. Loving it so far!
I have found a handy feature with the “Draw Size”. I don’t know if everyone knows this or not, but I cant find any posts mentioning it. If you set the “Draw Size” of a brush to 1 and click down to use it it will apply the effect to the whole surface and not just the area under the brush. Try it with the smooth brush!
If you decide to click down and drag the brush in any direction it will change the strength of the effect as you drag!
To test this use the smooth or inflate brush on an object.
It also respects masks!
So hopefully I’ve helped someone with this tip!
Also, how can I use an avatar?
Cheers.
