dragrect size problem
Hello!!! im new in zbrush.and its my first post here.
i do tutorial and i have a problem. when im sculpting with standart brush in dragrect mode,the size of brush is very big and when i change it ,its still big and there`s no changes at all.i checked all the settings,but its the same like in tutorial.whats the problem?? (sorry for my english)
DragRect always works by dragging out from the start point. So the more you drag from where you clicked, the bigger it will get. That’s the way it’s designed. If you need a different behavior, you’ll need to try one of the other stroke options. For example, DragDot lets you draw a single instance of the alpha at a specified size determined by the Draw Size.
