drag-dot stroke and tablet
When I use the Standard brush with Drag-dot stroke with the Intuos4 tablet, the tablet pressure doesn’t change the Z Intensity. But changing the Z Intensity slider at the top of the UI does affect the Z Intensity.
If I use the Dots or Freehand stroke then the tablet pressure does work.
Are there some settings I should use? Or is this expected behavior?
I’m using ZB3.1.
