Downloaded materials crash.
The solution to my problem is easy, the implications are not.
Yesterday, downloaded approximately six materials from the library.
Downloaded, extracted the zmt files.
Copied and pasted the six files to the materials folder.
Created polyshere, cranked up to about 130,000 poly.
Chose Best render and clicked. Sphere renders with material
and then crashes the program.
Only the six I downloaded do this.
Which version of ZBrush are you using, and which materials were they?
Merry Christmas Aurick!!!
Judging by the time of your post,you spent Christmas Eve
with this junk. Appreciate it.
Due to personal problems have not used Zbrush for awhile.
The version I have is, I believe, 3.1.
The solution, as I mentioned, was rather simple: delete
the offending files. It did not happen with the preshipped ones.
Am including a screen print of the offending files.
Incidentally, again, the setting was BEST and the render completed
within seconds before the crash.
This is not problem for me, but…
In any case, Happy Holiday, Happy New Year, all the best.
If you get a chance come visit us at the bottom forum.
You are always welcome!!!
Let’s first make sure that you’re running 3.1. Launch ZBrush and look at the title bar. It will tell you which version it is.
I have 3.1.
Noticed the time of your post, we will have to speak about
your hours later.
Problem may me moot, recently purchased a new computer,
was going to call next week about adding/extending license to
second one. If the problem only happened to me, may have
an immediate and permanent solution.
To recap, if problem is only me. no need to spend a lot of time on
it.
Thank you,as usual.
