'double-click reset zoom' trouble
Hi all,
When you double click the mouse (or pen) whith the alt key prest, you’ll frame your artwork. Is there a way to switch this off? It is pretty anoying when subtracting (standard brush with alt-key) with small strokes that every time it zooms out again.
my website: www.buroblinq.nl
I don’t think there is a way to turn it off but you might try lowering the Preferences > Interface > Click Time and/or Click Distance sliders. Adjusting just Click Time should suffice.
Thanks TVeyes, that seemed to help a bit. Though it is a bit strange that in a program that is so user configureable, you can’t switch off such a function. Oh wel…
this is unbelievably annoying. i hope they add better UI customization options in the future.
Yes there is a way to turn this off but it will also turn off the capability to ALT select subtools on the document instead of using the subtool sub-palette to select which subtool to work on.
just go to preferences>edit>auto select subtool
Paul
cool thanks. much better.
Hey, great trick, thanks gabo1991
You can use the macro in this post to assign a different hotkey for selecting subtools:
http://www.zbrushcentral.com/showpost.php?p=657400&postcount=5
