Dots Display
Is there a way to keep the Dots Display (WireFrame) Active without holding the LM button and dragging.?
Just want to view the mesh as a wire frame.
Thanks!
Dots mode is only active when the LMB is pressed.
You can duplicate a wireframe view through some tricks with the PolyFrame feature. Here’s what to do:
  1. Set Preferences>Draw>PFrame to 100, PFill to 0 and change PfColor to white.
  2. Activate PolyFrame (this must be done after the Preferences have been set in order for them to take effect.
  3. Change the Document Background to black
  4. Set the color to Black
  5. Set Render mode to Flat
  6. Draw your object. You may or may not wish to turn on Tool>Display Properties>Double
There you go!
Thanks! that worked great.
