Wow I’m always amazed at how much feedback I don’t get
Clay and wireframe.
Clay and wireframe.
Completely missed this one. Those keyshot shots look fantastic.
Fine details
Thank you guys! Very happy you like it!
Very old model, new render
Its so cool, when a virtual character is breathed into life!
Amazing!
Ciao,
TM
Ha ha ha - A lot of zbrusher seems to be lazy in posting feedback.
But on the other hand, what should I write?
You work is brilliant and I am always love seeing new sculpts or even render fun from you.
Thanks for sharing.
I try a lways to write something or a short comment
just to let know my support , about this thread i sit down and look with admiration
for all the excellent works cherub can produce - a suggestion? Keep on posting here!!
Thanks so much guys! You’re making me rally happy about posting here!
A new Keyshot render of another oldie. Fibermesh was also created for this occasion.
Excellent Joker…
Fancy sharing how you create your eyes?..
small_orange_diamond
Thanks Peter!
I generate a sphere in 3ds max, I wouldn’t recommend using the one from Zbrush because it has a hole actually on the pole points (not sure why though), and if I try to close it by close holes function the uv’s are all jagged. So I generate a sphere in 3dsmax, import to Zbrush paint a texture on it by hand to serve as a placeholder for the time being, then i select only the faces of the iris area and extrude them a bit out (not by extruding just pulling out), after that I export the uv’s and usually in Photoshop add a photo of real iris above the placeholder. Once in keyshot I use one of the plastic materials, I think it’s the dark waulgn or something like that I’ve renamed it so can’t remember the exact name. I tend to use that one at it’s default settings, apart tweaking the blend colour.
Here’s the image of that eye.
awesome Joker! It´s like Jack Nicholson just posed for a photo!
Would you please share your fibermesh settings?
Thank you so much Ernesto! I’m sorry but I don’t have the settings for it anymore, and I usually generate a new fibermesh for each model since every model is of different scale and one fibermesh just wouldn’t cut it. For this one I only remember I used 10 segments, and other settings just played by the ear till I got something I liked. Then I groom with only the groom short with collision settings turned down to 6 (under brush -> fibermesh), in this was I have pretty close to the head combing. Sorry I wasn’t of more help.
Sweet Joker!!! you’re work gets better every time, keep going! Cheers…
Mutte, thanks!
Great new renders Cherub! Congrats.
Thanks JL-Art glad you like it!
Here’s a new Keyshot render of old LeChuck. Photoshop for displacement (fire effect).
Wow very powerfull you can say more about this compositing
