Thank you!!!
I just woke up in the middle of the night cause I could feel all of your love.
Monstermaker, thank you for African woman and The Biker recordings you’ve made, they were what influenced me the most when starting portraits inside Zbrush. I will sure try to make a better portrait each time, just to have you visit
Thank you!
Thank you Revvels! For wrinkles I firstly used dam std brush to lay them down, then surface-noise (made it bigger on the cheeks, masked out the other sections before applying), then again used the dam std to bring them out more, and then used inflat brush to pull them as well as his “blobby” features out
I used clay brush at some points to more define some landmarks. And lastly the standard brush with drag rect + the standard lines alpha to “tie” it more together. Occasional irregularity with either dam std for pores and standard brush for moles.
JoseConseco, thanks! I will be uploading soon enough, but as I’m no expert in Camtasia recorder, something got out of place and the video displays even more insanity than I alone do, with all the zooming in zooming out each time I zoom in/out on a tool inside Zbrush. I was suspiocios that something like that will happen, so not to get frustrated I didn’t record the whole thing. About 1/3 is there, skull - and some face features, but not nearly complete. I’ll upload here within a day or two when I edit it a bit.
Thank you Mjolnir!
cartoonMike, I’m so glad you feel that way about it, it really is, as Michalis well noted, an *impressive (as in impressionism) portrait.
Thank you Dman3d!
Thanks Mcteapot!
Daphamer, thank you!
Thank you EricShawn!
Once again thanks for visiting and all of your support, in hopes R2 comes to us really soon and gives us all the power that we need.
Cheers
Dmitrij
small_orange_diamond
Thanks FoOD!
