You did a great job with that scenery Hansl, I think it has helped the rabbit considerably. As you know I am still unhappy with the texture, even at a size of 2048 it still smudged badly, causing any colour variation I put in the fur to just blur almost into one. I did start with UV tiles but that produced almost the same result, and of course you canāt do any correction work on that, the existing texture is spherical, but I couldnāt make much out of that either when laid out flat. Obviously I am still not very proficient at texturing yet; it looks like I have a lot of hard work to get it really right. Perhaps using the maximum texture size will have to be the answer to it, to get sharp really defined textures, anybody with ideas that has a knack for UV texturing, their ideas will be gratefully received and tried out. The rabbit is fairly low poly, I donāt have a problem texturing high poly models.
Anyway thanks for putting the rabbit in such a splendid scene Hansl, its top class landscaping work, very realistic.
Dave
