dividing after sculpting?
hi, im new to zbrush and i have a question that i hope you guys can help me with. when i started my model in zbrush i divided it about 3 levels. after that i started to sculpt a few days and its going pretty good. however im at a point where i want to divide it again but it says i have to delete the dividing history or lower the divisions?.. something like that. so is there a way to divide your model more after massivly sculpting it? thanks
My guess is that the model is partially hidden or partially masked. That’s how you tell ZBrush that you want to partially divide a model – something that can only be done at the lowest level. Press Tool>Masking>Clear and also make sure that no polys are hidden. That should resolve the problem, assuming that your system can handle four times more polygons.
thanks for the help, that worked. learning something new a the time.
