I have found a very annoying bug when you are trying to customize some of the UI elements within zbrush 4
For example let’s say you want to create a new menu (Preferences -> Custom UI -> Enable Customize -> Create New Menu ) with all the options of the layers sub menu (by default it’s located in the tool palette)
So now you can access it quickly by simply pressing the keyboard shortcut of your choice (instead of scrolling down the giant “tool” palette menu which can become annoying pretty quickly )
Well it’s not working. Some of the options do not display correctly (duplicate, rename and delete are replace with the ones from the subtool menu) and only the first layer you create will display properly
I really hope Pixologic can fix this pretty quickly !
