Displacement map not getting generated properly
Hi all,
I am trying to generate displacement map for one of my models but it is not getting generated properly…
jus take a look at the tiff image for displacement map and also the displacement export settings…
What are you trying to render in? Have you read the appropriate “ZBrush to X” guide for your rendering software?
I generated the Displacement map after reading the guide!! I am trying to export 32 bit displacment map for using it in maya!!
I actually generated the Displacement map after posing the model…
But…when tried to export displacement map from the unposed model it is working properly!! :confused:
I progressed with my work with the displacement map from the un-posed model…but wat went wrong with the posed one?? :qu:
Not sure…
:mad:
