Hi, that’s the first time I encounter this issue and I really don’t know how to fix it.
My displacement map is always exported at the same place, with MD3, even if I choose the location with the Export option.
It save me 2 maps, one map who seems to just be the current selected alpha and the other who is my correct displacement map on an other location that I don’t know how to change.
What is the pathname that you’re saving to, and what is the filename that you’re using?
I think I know where the problem come from but I really don’t know how to fix it.
I remember having created a shortcut where I change the field “Start in” to be able to start everytime in my project folder.
But I checked all my shortcut and this field is the default.
But my displacement map is saved in this field and here name is not the name I mentionned it in MD3, it has the same name of my project folder.
My project path is “D:/xxx/yyy/ProjectFolder/CurrentProjectFolder” (that’s the path I place in my shortcut) and my displacement map is saved in
D:/xxx/yyy/ProjectFolder and it is named CurrentProjectFolder+R32.tiff.
But I also have the correct named filed in the correct folder but it has nothing in.
I got two file, the good one in the field I didn’t choose in MD3, and the other in the right place but who is not the correct displacement map.
I hope I was clear enough.
