displacement export problem
Hi guys,
I’m a new user in zbrush and i’ve been following the digital tutor tutorial so far. I have problem with exporting the displacement map from zbrush. Everytime I click the ‘create all’ button under multi displacement 3, it just wont work. Zbrush doesn’t seems to do anything. Did I set something wrong here? Thanxs :slight_smile:
did you look under the alpha tab?
Hi
Thanxs for the reply.
I found out what the problem is. It turned out that you have to have a UV map first before you export the displacement map.
