I am having a problem with creases. My geometry is divided at level 5. I created uvs, created my displacement map and my model has creases on the original poly flow. It is also showing very small poly faces. I have imported the model into c4d applied the dis map and get the same results. Please help. I must have this model rigged in 24 hrs. I will attach an image of the model at 5 divisions with the dis map applied in zbrush.
