Hello!!
I have done the UV MAP with “blender” , I have imported the “obj” with the UV in “zbrush” .I have done the “UV check”.I have the map.TAKE OFF the UV MAP and prepare for “displace map” .
“adaptive”,“smooth” and after I click for"create displace" but NOTHING HAPPEN.
WHAT’S THE PROBLEM?
thank you
bye
Hey, maybe we can help each other. I am a newbie Blender user and I want to import my ZBrush file into Blender and apply my ZBrush displacement map, but I can’t find a tutorial that thoroughly explains this. Do you know how to do this?
yes,of course.
can you explain how can I make the displace map?
bye
Make sure you’re at the lowest subdivision when you create the displacement map.
Richard
I have SDIV 1.
That mean that you have just one subdivion ?
If is it the case you can create any noraml map or displacement map.
Otherwise, in ZBrush 3.5 you have to clone the displacement map that you created (it is shown int the displacement tab) and then go to the texture menu and export).
Hi, have you figured this out yet? If not let me know what is the problem and I can help. I need some help with applying my ZBrush displacement to my model in Blender too if you can help I would really appreciate it. Here’s the link.
Thanks CGICore, actually I understand the ZBrush end of things, but applying the maps to the model in Blender is what I was having trouble with.
n/p.
