Hi guys, I’m very principiant about zb.
I’m trying to do some example for learn it.
Then, if I try to use Terrain tool (default) I’ve no problem
My steps:
-import tool (terrain)
-subdivide and sculpt it
-level 1 and Store it (morph target)
-in displacement, “adaptive” and “smooth UV”
- in MD3, export map “Create all” with the default parameters
If I try with a my column, doesn’t work. It creates a gray map, without nothing. I don’t understand it (my oby has UV ok, see last image on right)
why that? where is it wrong?
Thank you:)
