Disk Space
Every time I Goz an object in Zbrush 4r6 to Maya 2014, it always says I have critically low space, even when I deleted alot of applications, files, and downloads. What do I do?
Hey! I am Having this problem too!! Please help!
Do you have the latest update, ZB4R6 P2?
Please, go in the Troubleshoot Help folder located in the ZBrush folder and run the GoZ_for_ZBrush_Installer_WIN.exe or GoZ_for_ZBrush_Installer_OSX.app application.
It should help your problems. Most the time this issue is cause by a permission issue, ZBrush and GoZ can’t write temporary files.
I figured it out and yes it was a permissions issue… Thank you for your help!
i don’t have p2… Does it make it better?
The search feature is giving me problems it couldn’t find goz in the forum… Found this page from google… :confused:
Hello. I know this is an old thread but i figured it would be better to ask here than creating a whole new thread.
How do you solve this memory issue? i used to have it only on GoZ but now it’s expanding. UV master hangs on it and sometimes even poly paint.
I’ve tried going to the ZBrushScratchDiskPath.txt and changing the path there to use my external drive but i keep getting the issue.
I also tried a clean install but the issue persisted. Tried changing the permits though it said i could read and write and keep having the issue.
Running on i5 with 8gb of ram and i have more than 100 gb of space on my internal drive and close to 1TB on the external one. Not great, sure but it should be enough… i mean, it used to work.
Any help would be appreciated.
