I’m having some serious difficulty with a current project. I have a tool that i’m working on and I just added a set of eyes to the sub-tools. The problem I’m having is when I try to find the eyes in the sub tools they are not able to be seen on the canvas, even if I hide the other sub tools or hit f to center them. I have tried several different eye tools and other items and anything that is small just is not visible to find. Help.
Hi I was wondering if you ever solved this this problem. I am going through the exact same trouble right now. I made a Zsketch and have an older version of the file that still does work, but the latest file has about 3 hours of work I don’t feel like redoing. I tried flipping the normals, turning off the transparency, cloning the tool, exporting the tool as an obj, and several other things, but still no luck.
If a SubTool disappears, select it in the SubTool menu and then press Edit>Tool Undo. This should make it visible again.
