Disable right click menu
I find the menu which pops up when you right click to be extremely annoying. I navigate using RMB and I often get the menu up by accident, where I unintentionally change attributes in my scene like intensity, focal shift and so on.
So, is there any way to disable the menu?
I am a newbie but you can enable “right-click navigation” in preferences, so instead of the menu you’ll get the possibility of scrolling panning etc even when you tool fills the screen.
This said I wish I knew how to kill both the menu AND right click nav, I’ll be following this thread to see if someone has the solution.
Cheers!
U
Well, disabling RightClick Nav in the preferences will only make me not navigate using RMB, which I don’t want to, as I prefer that method. It doesnt disable the menu though. I’m guessing that the way to disable it would be to find some soft of script, as I can’t find anything in the preferences.
bump
this is getting quite annoying now …
I also love using the RMB navigation but it still has a lot of unrefined facets :
1- with the RMB navigation the menu you also specify is useless as we have the Spacebar menu, and is annoyingly popping out when you don’t want it.So a disable option would be great in the Preferences menu.
2- RMB navigation it still behaves as it touches the model and it fixes the impact point as a camera orbiting pivot…this thing i presume it shouldn’t happen but is manageable …
3- Another annoying thing with RMB navigation is that when you use the Transpose tool, if you put the cursor on the model to RMB navigate , actually it moves the transpose tool and I think RMB should be completely neutral.Many times I found myself navigating with RMB while using transpose tool and I moved my subtool away without being aware of that (with Solo mode).
