I’m working at the dino. Before it I have done the island in programm VUE. Textures of rock are made in ps. In animation the models were taken from VUE model’s library. Here is the screenshot of animation:
Very good start there shserge, the detail adding is very memory intensive so a memory upgrade would really make a difference.
If you can afford it 2Gb will get you around the 2 millon mark no problem (depending on your cpu) it will also improve you other softwares performance, especially Vue…
The higher the polycount the more detail you can add…
Thank you for help, Buckie! I’m glad you like it
New updates for the island itself (above) and dinosaur model:
Dinosaur model rendered in 3dsmax with normal maps
