I sent my model from DazStudio to Zbrush using the GoZ plug-in. Zbrush automatically opens with an empty canvas and my model was nowhere to be found, not even in the toolbox. Where should I be looking for my model? Help is much appreciated.
1) Have you installed the DAZ GoZ bridge as should have been described by the instructions from DAZ? If not, ZBrush wouldn’t know how to handle the data being sent to it by DAZ.
Have you used GoZ to send a model from ZBrush to DAZ? In most cases, the bridge will not work correctly until you’ve first sent a model out of ZBrush.
Which version of ZBrush are you using? Have you made sure that the GoZ implementation you’ve received from them is compatible with your version of ZBrush? For example, I don’t know if they’ve released their update for ZBrush 4R3 yet.
If you’re still having problems you’ll need to speak with DAZ support regarding this since the GoZ bridge is being implemented by them using the SDK we provided them. It’s a situation where we provide support to them and they provide support to you.
- There are no described instructions, not even a manual for the daz programs.
- guess ZB4R3 works, as someone used the fibermesh hair brush on the models so
