different colors on subtool description (info)
Hi Everyone, just a quick question about subtools info. When I hoover over it on the subtool palette one of them is giving me all the infos coloured in yellow and not in white as it normally does. The same subtool in a previous file was displaying the infos in white, but whe I append it to another subtool list it changes. any ideas? Thank you.
S.
There’s no significance to the color, as far as I know. I suspect that it’s something to do with the length of the description and combination of characters that causes the color simply through an accident of coding. Anyway, it’s nothing to worry about.
Hi Marcus.
Actually didn’t cause any particular problems, as far as I can see…was just out of curiosity.
Thank you very much for the quick reply.
S
Greets. One thing I noticed right away is ZBrush 4R7 on top. There have been 3 patches for it. You should try to get updated to the latest patch; (it should say P3 after ZBrush 4R7)
Clearly you have made a lot of changes to Zbrush’s interface default colors, so my guess is that perhaps you accidentaly changed some parameter, or maybe it’s a little harmless bug because of these changes.
Thanks for the replies guys. Didn’t create any problems and just upgraded P3! Thanks!
