Difference between polymesh and adaptive skin
is there a difference between converting a zsphere-model to an adaptive skin or click the make polymesh3d button in the tool palette? And if there is, which of them would be the better solution? Thanks in advance
The Adaptive Skin will give you subdivision levels, depending on the value in the Density slider. The Make Polymesh 3D won’t have subdivision levels (but you could reconstruct them if you wanted). So there’s really little difference.
hey marcus, thanks for your reply! Now I see a bit clearer :eek:
