Did we lose 4K monitor support in Zbrush2018?
Zbrush no longer fits on my screen. Why is this happening and how do I fix it?
I can’t find any options for UI Scaling, only the button size slider and that didn’t help.
check the button size in preferences. reduce it by 5 or so and see if that makes a difference. if it does, resize your document to fit and then save it as a new start up document.
I’m guessing you’re on Windows? You’ll need to right-click on ZBrush and go to Properties >> Compatibility. There, turn on the Override DPI Scaling box, setting it for Application control.
Your operating system is seeing ZBrush 2018 as a different program from ZBrush 4R8 (which it is, despite the name) and so is reverting to its default behavior of upscaling everything – which in turn makes it look like merdhe!
Once ZBrush has control again, the Buttons Size slider will let you fine tune the appearance so that you’re happy again.
Yes, I’m on Windows 10. Thanks for the tip!
Thank you! This helped fixed my problem!
I was having the issue with the interface being way too small on the Cintiq Pro 24 with Windows at 100% DPI scaling. I found scaling any higher than 100% would fix the interface being small, but you would have to sacrifice detail/sharpness on the model.
The solution that worked for me was indeed the ‘button size’ setting.
It is located under Pref > Interface > UI. By default, it is set to 47, I believe, which is way too small for a 24" 4k Cintiq. I’ve found a good size to be between 65-80. I settled on 70. =)
