High guys I’m new here
I have some problems with my first zBrush model, a Dewback from Star Wars.
Some parts of the model overlap some others, I started to work with zSpheres and then I converted it to a 3D mesh and modeled over it, this is the result after only a few hours in zBrush
<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
You can see that on the head some parts overlap some others, I’ve the same problem on the feet too and I don’t know how to fix this, can anyone help, please?
you need to post your pictures properly. we cant see them.
Hmm, I don’t know why my images aren’t posted
(I used “Insert Image” )
So here are the links:
http://img810.imageshack.us/img810/572/dewbackframe2.jpg
http://img36.imageshack.us/img36/3161/dewbackframe1.jpg
Thanks for help
Insert Image links to outside sources. ZBC does not allow this. Instead, you need to upload the image to ZBC and then insert it into your post.
See here: http://www.zbrushcentral.com/showthread.php?t=68060
Ok so here are the images of my Dewback, and so you can see my problems: head, feet and legs
Does anyone know how to fix this?
Thanks for help
