Depth of field
Can it be done, when i stay inside of zbrush? In other words, has the Zbrush renerer that feature? And, if yes, where is it to be found?
Thanks
Heiner
alpha>grab doc, alpha>export and reassemble in photoshop.
too bad, that i will have to leave ZBrush. Anyway, is there a goot tutorial on this external composing workflow?
Cheers
Heiner
zbrush does have DOF its in the render palette.
http://www.zbrush.info/docs/index.php/Render_Palette
