- when I turn on “Depth cue” in render options, set the points of depth and render with BPR, it renders without blurr.
But when I render with “Best render” it render it just like it must.
When I set up “BPR filter” BLUR it renders it ok,… So, Can someone tell me is there any way to make “Depth cue” to work, and if its not, then why it is still there in options???
- whe I choose “Flat material” in Zbrush4, turn to render “BPR shadows” and/or “BPR AO” in render options, it renders it so I can tweak the parameters. But ib Zbrush4r2 its not render anything, it just blank…
is there an answer to all this things?
