ZAmigos, I appreciate all the support, comments, and suggestions…
Jason, Thanks for taking a moment from your proliforation of postings to give some input.
I appreciate it.
Atwooki/Chris, Thanks for your help from the start
I will definately check out that material and lighting setup, for sure. If I am digging it, I’ll post it here. Cheers mate!
OrrieWalls, I appreciate the insightfull approach you’ve suggested as a means to decide coloring. It is a good idea worth delving into.
Womball, I see how big the post showed up, and yes, it is difficult to absdorb all at once. I will post a side view, just for you pal.
Marcus, thanks for your support, your another real pal and “super-genious” :idea: A render with GI shadows…(Do I just select the “Shadows” box in render?)Hmmm?
Jlizzle, thanks for the support, and the link! The transition fron clay to 3d isn’t that easy, alot to learn at first, but I think once you start to get the hang of it, it’s gets easier(?). I still can’t believe how much more their is to learn :o Great link too! I definately will be influenced by it. That Pierre Bourgeot is one talented dude, and good call on your part, as his coloring is very rich in charactor. Thanks again.
Nick, hey pal! Good hearing from you! You’ve been a pal from the start too. Thanks for the kind words…(What is GI???) Sorry…:rolleyes:
Again, thanks and I will keep everything in mind.
Cheers guys!
~BW
