Deleting Hotkey
I just re-installed Zbrush4 on a new computer and I have a small problem that I need help with. I’m using a drawing tablet and every time I press down with it, up pops this small meny under the cursor. As far as I can tell a hotkey is assigned to show the quickmeny every time I right click. I’ve done over one hour researching how to remove it but the things suggested doesn’t work. The delete key does not delete the hotkey. It possible that I’m not doing it in the right sequence. I also tried the new hotkey editor without any luck. I also went in and removed some lines in the startup hotkey.tx file but that didn’t work either.
Any help with this small but irritating problem would be greatly appreciated<img src="http://www.zbrushcentral.com/pixo/atn.gif">
Oh, I solved it myself! I had to change the settings on my input device… Nothing to do with zbrush, really. Sorry about that<img src=“http://www.zbrushcentral.com/pixo/atn.gif”>
