Deleting an object?
I have a 3D model, created from ZSpheres. How do I go about deleting it? I looked through the help and the Keyboard Shortcut guide, but must have missed it.
Thanks
Where do you wish to delete it from?
If it’s on the canvas and is the only thing on the layer, you can simply clear that layer (Ctrl+N).
If it’s in your tool palette, it will be removed automatically when you restart ZBrush.
If it’s on the canvas and other things are also on the layer, it’s not so easy to get rid of. The Eraser tool can be used. Or if the object was the last thing drawn you can use Ctrl+Z to remove it by undoing it being drawn.
