delete meshes from insert multi mesh
I’ve created an insert multimesh with a few different meshes in it…how do i delete unwanted ones from the multimesh?
You can’t delete them directly, you need to make the brush again. The simplest method is to load the original ZTL that you used to create the brush. If you don’t have that you will have to use the Tool>Geometry>Modify Topology>Mesh From Brush button to extract the meshes you want.
hmm…okay…seems like they need to add this simple functionality into it
