Delete Custom User Menus?
How to Delete Custom User Menus?
Currently, the only way I’m aware of is to restart ZBrush without saving the UI. Or if you have previously saved a configuration that has custom menus and now wish to remove them you will need to delete your CustomUserInterface35.cfg and create a new custom UI from scratch.
I personally recommend copying your custom UI file before you start fiddling with creating custom menus. Save your UI when you’re happy with a menu (and copy the new file so you can always revert if you want) before moving on to the next one. This will avoid the frustration of having put a lot of time into building multiple menus only to change your mind or run into a problem with the final one.
