Default window settings
Is there any way in ZBrush 4r4 to set the default window settings for the main window when starting up? My current zbrush window is too big at startup and covers my autohide taskbar so I have to reset it each time.
Thanks…
I believe aurick posted this suggestion a while back. You click the ‘Restore’ button in the top right corner to change to window mode, then resize the window to fit in your screen then ‘Store Config’. Yes, this works everytime you start ZBrush, but if you minimize and then maximize the window, ZBrush fills the entire screen again. No way around it either. This pisses me off too.
