Default texture size????
Hi All,
Is there a way to set the Default texture size that zbrush creates when you select Col>Txr? it always creates it as 1024x1024 which in my case is too small.
Simply apply a blank texture of the desired size to the model before you press Col>Txr.
Go to the Texture palette. Set the desired size. (For best results, it should be a power of 2 such as 2048 or 4096) Then press New.
Thanks for the reply aurick
but my problem is if i want to re-work on the texture and do a Col>Txr it creates a new 1024 (lower res) image instead of the higher-res i had to begin with. I’m obviously doing something wrong but in all tutorials i’v found it doesn’t show how to do this
Steel gate valve is excellent for use anywhere a shutoff valve is needed. Steel gate valve can also be used where throttling capabilities are desired, although this is not generally recommended as erosion of the seat and disc occurs due to the vibrations of the disk in throttling applications…from the site www.ulovalve.net/gate-valve.htm
