I have recently encountered this issue, where I will be in the middle of sculping and my default brush or masking brush will suddenly become really faint. It makes painting masks very difficult, needing many strokes to become 100% and just being too soft. I thought it was maybe some settings that changed, but I caught the behavior in the middle of a stroke, so no settings could have changed.
The still image shows it mid-stroke changing.
I could not capture this behavior on GIF, but I can show how the clay brush seems normal while the default brush is very faint. Once again, I have not changed any settings, in fact to record this I restarted Zbrush several times. (there’s some compression, but basically the clay stroke is 100% opacity, and default brush stroke is 10%-ish opacity, while opacity for RGB is on 100%, and the same happens to masking)
Any ideas what could be causing this?
(I also noticed the Gradient option was on and causing some weird colors, when I don’t remember enabling it myself, but that was an easy one to turn off)
