Decrease draw size shortcut doesn't work.
Hi!
I’m having trouble mapping my decrease draw size shortcut to [ (or any other key for that matter…)
I go to Zplug-insMisc Utilities and by default it’s mapped to [ but pressing this button while sculpting and nothing happens (increase draw size on the other hand works just fine in its default ] mapping though…).
So then I press alt+ctrl and try to map it to another key just in case, but mapping it to another key still doesn’t make it work while sculpting. And also, every time I try to remap it back to the default [ ZBrush instead maps it to F12… :cry:
It’s very frustrating. Anyone knows how to solve this?
(btw I’m running ZBrush 4r4 on Mac OS X Lion 10.7.4 using a Wacom Intuous Pro)
You should be using ZBrush 4r6 P2. ZPlugin>AutoUpdate
I know, but I’ve just picked up ZBrush again after being away from it for a while and just haven’t got around to upgrading yet. Will do though :D.
Not sure if doing so will magically sort my shortcut problem though…
PROBLEM SOLVED:
(hopefully permanently…)
I restarted my computer as well as ZBrush and this time, while the default [] still doesn’t work, when i now remap increase/decrease to those very same bracket keys they both work this time.
Even if ZBrush still refuses to map decrease draw size to [ and forces it to F12 instead it now actually decreases drawsize when I press [.
:D:D:D
Usually, just toggling Dynamic button allows the draw size to be minimised really small.
