Decimation Master Exporting
I use Topogun. Is there a way, after I’ve decimated all of my subtools with Decimation Master, to export a single OBJ with each subtool retained as a separate object within that single OBJ, and also have each subtool retain it’s name?
I’m currently exporting each subtool individually, bringing them all in to Max, naming each one, then exporting them back out as a single OBJ. It would be great if I could skip all that and just get what I need out of ZBrush.
have you tried to processes all and decimate all. then you can use subtool master to export out all of the decimated meshes. I believe that is exactly what you’re looking for.
There’s an Export All Subtools button on the bottom of the Decimation Master pallet, but when I bring the OBJ into Max the names of the subtools are lost. They just read subtool1, subtool2, etc.
