Hello everyone.
I have recently attempted to “sculpt” a Z-brush model using the dam standard brush tool. The problem is, the dam standard brush is not reaping the same results as was seen on Simon Blanc’s “No more Wine” tutorial.
Whenever I use the dam standard brush tool along with the drag rectangle stroke (as seen on blancs tut) all I get is a big pinch of vertices together in one area (and NOT the straight lines that Simon was able to achieve.)
Does anyone know why when I use the dam standard brush tool with drag rectangle stroke, I even recieving “pinched” areas, and not straight lines?
I have also tried the Dam Standard tool with the draw stroke, but the lines I create seem to be “jittered,” and not as smoothe as ones created with the “pinch” tool.
Can someone tell me what I have to do with the Dam Standard brush tool to be able to draw the fine details Blanc was able to in his tutorial?
