Cycle through material Macro?
Is it possible to make a macro who let you cycle through chosen material?
If you mean cycle through the loaded materials, that is easy enough to write. Put the attached file in the ZStartup/Macros/Misc folder and restart ZBrush. You’ll have a new macro button called ‘CycleMaterials’ in the Macro>Misc submenu. Press the button to change the material. Assign a hotkey to the button if you wish.
Thank you Marcus!
That’s almost what I wanted to do, I don’t even know how to do such a simple script so thank you for your help.
But what I wanted was to cycle through just a few material that I could choose.
While sculpting I am switching from Basic Material to be able to tweak my lighting, a clay like Matcap and the Outline matcap.
I wanted to cycle through these three material without having to search through all the material.
Like the script you have done but just for these 3 materials.
The simplest way of doing that is to assign hotkeys to the different materials. For example, you might choose 1, 2 and 3 on the keyboard. To assign a hotkey:
  1. Click on the large material thumbnail in the Material palette so that the pop-up appears with all the materials.
  2. Ctrl+click on the material you want.
  3. Press the hotkey you want to use.
  4. Repeat (2) and (3) for the other materials.
  5. Store the hotkeys before closing ZBrush (press Preferences>Hotkeys>Store).
HTH,
there is also this great script that marcus wrote that i use every time i use zbrush:
http://www.zbrushcentral.com/showthread.php?t=63296&page=3&pp=15
