cutting out object
Hi
in rhino or max there’s a tool to cut out an object with other cutter ’ called boolean subtract’. in zbrush is there a tool that does similar or same thing other than using dyna mesh??
thanks in advance
yes, but they are all basically dynamesh. You can use the boolean options for subtools and remesh all
