Its been a while since I’ve used zbrush, and I need a bit of help.
I’m trying to cut a hole completely through a mesh.
For example, if I had a cylinder and wanted to cut the center of it out (to make a ring), how would I do that?
I tried using the Clip Circle Center w/ the alt key, but that didn’t cut a hole like I thought it would… It added to the mesh.
Not what I wanted to do.
So, what is the best way to cut a hole in something?
I used to do this all the time, and I swore that I used the Clip Circle Center brush… AHHHHH.
Thanks for the help!
