Customizing UI problem
Hallo!
Could anyone help me with this, pls? When I sculpt a model I like to customize my interface. I save brushes with special settings for sculpting and then move their icons to bottom shelf and then I go to preferences config and press save UI button, which should let me save placement of all icons. When I restart Zbrush, brush icons are away. Do I something wrong?
Thanks for answer.
V
Try this:
  1. Save your custom brushes to the ZStartup\BrushPresets folder. That way they can be loaded automatically when ZBrush launches.
  2. Restart ZBrush so that it loads your brush presets into the exact slots that they will always use.
  3. Customize and save your UI
I’m not entirely sure it’ll work, but it’s the only way I can think of that would be possible for what you’re trying to do.
Thanx aurick.
What you suggested works perfectly.
V
